01 Beetle bearing problem
Old Jul 3, 2008 | 02:21 PM
jasunderland's Avatar
Default 01 Beetle bearing problem
Hello all! On my wife's beetle (yes, i am talking about her car), I am pretty sure the left front wheel bearing is going bad. The car has 78K on it. I was wondering if anyone has had this problem and wanted to know if it is an easy do-it-yourself job? Also, does anyone know what size nut is in the center of the hub? I know it is bigger then a 27mm and less then a 36mm ( those are the front and rear axles on my bike). Any help is appreciated!!!
Old Jul 4, 2008 | 09:52 AM
Jrailer's Avatar
Default RE: 01 Beetle bearing problem
press in bearing best to have a shop do it
its a two hour job for a shop to do
Old Jul 7, 2008 | 05:51 AM
Is removing the hub something I can do and then take it to a shop to have pressed in and out?
Old Jul 7, 2008 | 07:52 PM
Jrailer's Avatar
you could try but the struts are a bugger to get in and out of the spindle thy fit into the spindle through a hole and are not much fun if you dont know what you are doing
they are notfun evenif you do
Old Jul 21, 2008 | 07:55 AM
Well, took your advice (even though you didn't come right out and say it) and took it to a local VW non dealer mechanic and it cost me $197.00. I didn't that was too unreasonable. but he did mention that he could hear the passenger side bearing start to make some noise, though it did not need replacing yet. The bearing he replaced it with was a *** brand [sm=icon_quiet.gif]
Kyo_clone
May 12, 2008 05:35 PM
minchulshinn
Sep 29, 2007 02:35 AM
relabbe
Sep 9, 2006 05:13 PM
menehune25
Aug 25, 2006 06:24 PM
mdmilla1
Jun 8, 2006 06:04 PM
