95 JETTA GL MOTOR SWAP PLEASE LOOK
HEY I GOT A 95 JETTA GL AND IM THINKING OF WAT I CAN DO WITH IT FOR $1000 IM THINKG OF MOTOR SWAP FOR A VR6 OR TURBO THE 2.0 BUT I DONT KNO WAT WOULD BE A BETTER BANG FOR MY BUCK
I NEED HELP TO CLEAR OF MY MIND ON WAT TO DOO I WANT MORE POWER ALL HELP IS A PPRITIATED THANKS ALSO HAVE THE 3.2 IN MY MIND BUT DONT KNO IF I CAN FIT IT IN OR NOT ALL THE HELP I CAN GET WOULD BE NICE THANKX |
RE: 95 JETTA GL MOTOR SWAP PLEASE LOOK
hey hey......nice car......the best idea that i have in mind for your jetta would be the VR6. reason being is that i looked around online and i found a bunch of people use supercharges and turbos both on the VR6. i have a VR6 but it needs alot of work. so you know if you buy a VR6 of that year its the same engine in the golf passat and jetta its just laid out different. but the parts are the same. other than that i think you will have it. good luck.......
the vr6 would be a good way to go, you could turbo your 2.0 but if you dropped the vr6 in you could save and then turbo it and have a jetta that will hang with sti's and evos
