Possible Voltage problem 2013 jetta hybrid
I’ve been experiencing a possible voltage drop however I don’t know what it’s from. I’ll be driving the car and I’ll loose the transmission completely. Then it just throws a check engine and epc light and won’t move until a couple hours later when it resets it’s self.I’ve also tested both the battery and alternator and they are good.
01-Engine Management: 6 02-Transmission: 7 03-Brake Electronics: 5 05-Start Auth-Kessy-Entry: 1 08-Airco: 3 09-Central Electronics: 10 15-Airbag - SRS: 2 16-Steering Wheel Electronics: 2 17-Instrument Cluster: 2 19-Diagnostic Data Interface-Gateway: 2 25-Immobilizer: 2 2E-Media Player Position 3: 2 37-Navigation System: 3 42-Door Electronics Driver: 3 44-Steering Assist (separated): 0 4F-Central Electronics II: 0 52-Door Electronics Passenger: 3 61-Battery Regulation: 0 2B-Electronic Steering Column Lock: 3 51-Electric Drive: 0 8C-Hybrid Battery: 0 OBDII Codes ($03): 2 OBDII Permanent Codes ($0A): 1 01-Engine Management P30A100 | Engine Start Interruptions, Permissible Number Exceeded U101700 | ABS Brake Control Module Read Out DTC U010100 | Lost Communication With Tcm P036600 | Camshaft Position Sensor "B" Circuit, Bank 1 Range/Performance P091900 | Gear Shift Position Control Error P044200 | EVAP Emission Control System (Small Leak) Leak Detected VIN MAKE YEAR MODEL ENGINE SYSTEM LICENSE PLATE ODOMETER 3VW637AJ2DM278500 Volkswagen 2013 Jetta (VIN 9M) 1.4 TFSI 157262 MI Page: 2 2013 Volkswagen Jetta (VIN 9M) 1.2L MPI (CBZB) Date: 02/04/2022 07:34PM 02-Transmission 54272 | Function Restricted due to Insufficient Voltage-U1400 05636 | Internal Control Module Output Driver IC Error P1604 05636 | Internal Control Module Output Driver IC Error P1604 Upper Limit Reached 06228 | Powertrain Data Bus Hardware Malfunction P1854 05913 | Functionality limited due to Engine Control Module P1719 05940 | Starter Enable from Selector Lever Sensor System P1734 06300 | Function Restriction due to Insufficient Pressure Build - Up P189C 03-Brake Electronics 02214 | Tire Pressure Warning Lower Limit Reached 03409 | Rolling Mode recognized 00668 | Supply Voltage Terminal 30 Lower Limit Reached 01325 | ECU Tire Pressure Monitoring - J502 No Signal/No Communication 01315 | Transmission Control Module No Signal/No Communication 05-Start Auth-Kessy-Entry U101100 | Supply Voltage Is Too Low 08-Airco U101100 | Supply Voltage, Voltage Too Low B10AA31 | Rear A/C Control And Display Head, No Signal D03C00H/13646848 | Refer to OEM repair information for code description 09-Central Electronics 00446 | Function Limitation due to Under - Voltage Lower Limit Reached 00532 | Supply Voltage B + Lower Limit Reached 00979 | Bulb Right Dipped Light - M31 Open Circuit/Short With Power 01315 | Transmission Control Module No Signal/No Communication 01497 | Blinkers Front Right - M7 Open Circuit/Short With Power 01499 | High - Beams Right - M32 Open Circuit/Short With Power 02394 | Parking Light Left Front (M1) Open Circuit/Short With Power 02395 | Parking Light Right Front (M3) Open Circuit/Short With Power 02746 | Bulb For Daytime Running Light: Right Open Circuit/Short With Power 00332 | Control Circuit for Tank Flap Not A Plausible Signal 15-Airbag - SRS U101100 | Supply Voltage, Voltage Too Low B10B400 | Functional Restriction of Seat Occupied Recognition due to Under voltage 16-Steering Wheel Electronics U140000 | Function Restriction Due To Insufficient Voltage U101100 | Supply Voltage, Under - voltage 17-Instrument Cluster U111100 | Function Limitation Due To Missing Message U101100 | Supply Voltage, Voltage Too Low 19-Diagnostic Data Interface-Gateway 01315 | Transmission Control Module No Signal/No Communication 00532 | Supply Voltage B + Lower Limit Reached 25-Immobilizer 9456128 | Engine Control Module (ECM) not authorized B104A 9456640 | Key: Implausible Signal B104C |
| All times are GMT -5. The time now is 02:14 AM. |
