-   Other Volkswagen Models (https://volkswagenforum.com/forum/other-volkswagen-models-35/)
-   -   heat issue CC (https://volkswagenforum.com/forum/other-volkswagen-models-35/heat-issue-cc-37561/)
kidd2018 Feb 17, 2018 11:48 AM
heat issue CC
Hi guys. I am having heating issue on 2011 vw cc. Heat only comes from the driver side and its slow. No heat from the other side. The passenger side blows cold air on the feet side. Any help I would appreciate so much.
Keithuk Feb 18, 2018 08:41 AM
This problem isn't easy to diagnose on the web without seeing the vehicle.
You need to get your motor scanned (preferably with VAG-COM\VCDS) for any error codes logged in the ecu and post them, that will save a lot of guessing. That's will also test the system out.
