cabrio 2.0 turbo kit
http://www.bahnbrenner.com/vw_audi/p...AGE3_TURBO_KIT
anyone tryed it? seen it? herd reviews on it?
im lost....SOS!
im lost....SOS!
www.eurocustoms.com has good prices on manifolds, www.atpturbo.com has all the hardware (oil, coolant lines etc...) and look on ebay for a wastegate and intercooler. www.godspeedproject.com also has good prices on intercoolers and turbo's. Also google c2 motorsports they make a good 2.0 turbo program for your ecu. If you shop around you could put it together for under 1500 easy. you could take the money you save and get some rims or something else. Oh and the most important peice of advice I can give is join www.*********.******.com and don't let anyone tell you turboing a 2.0 is a bad idea.
ORIGINAL: dubalicious
everyone iv talked to has said that 2.0's turbo'd generate a great amount of power, what size turbo do you recemend i should go with? i still have all factory motor and im kinda worried about overboosting
get a low comp head gasket and you should be good for about 12 psi. I would recomend a smaller turbo. somthing with about 50mm trim air side and a smaller hot side cause chances your not going to be pusing over 20 psi anytime soon so a smaller hot side is gonna give you better low end power. go with like a t-25
i'll do a lil shopping on that. iv herd that if you get the head spacer you run the risk of blowing it out with to much boost? but yeah 12psi really isnt much...i dont plan on running anywhere near 20psi until i can get a vr6 motor build going on. thanks again dub, youv been a great help
ilove2xlr8
Nov 15, 2010 04:55 PM
20, 2001vw, 2006, cabrio, cabriolet, kit, kits, make, manifold, put, turbo, turbocharger, volkswagen, volkswagon, vw
