boost controler questions
so i have an 03 1.8t and I am wondering if anyone has tried to put a manual boost controler on, i would just go ahead and do it but the whole throwing off the ecu issue is something i want to avoid i figured i would just ask. Will this work with out throwing off the ecu? and if it does work what hose/hoses do i hook it up to? any tips are appreciated.
RE: boost controler questions
Where did you hear it would throw of the ECU?? Well if it does it would give you a reason to re-map it with the GIAC software..lol
true, should i just avoid it and go for the giac?
yea why not, mine was $300 for the software. so after you put the gauge in, then get the software upgrade.
what gauge? i already have a boost gauge if thats what you mean...
not the gauge I meant the controller, my bad.
| All times are GMT -5. The time now is 02:56 AM. |
