-   Interior (https://volkswagenforum.com/forum/interior-8/)
-   -   Accidental short interruption of the engine while driving (https://volkswagenforum.com/forum/interior-8/accidental-short-interruption-engine-while-driving-38266/)
Zdeno Aug 25, 2020 04:41 AM
Accidental short interruption of engine operation while driving in a higher gear (4 to 5):
The engine stops accidentally while driving. I Feel the engine jerk.
Since the gear is engaged, the engine will start immediately and continue driving without interruption. The yellow 'Engine' indicator light comes on on the instrument panel. This goes out after some time.
This event occurs considerably more probably when there is less gasoline in tank then the tank half volumen.
The OBD codes: P0203, P0204 and P0322
Keithuk Aug 25, 2020 08:22 AM
As I've said in you other post.
Before I post those error codes.
