VW U585 using tech guide
How to use U585?
Share a youtube video: http://www.youtube.com/watch?v=GxYMB...TPX4NUdRb25OM= Functions: 1.Works on all 1996 and newer cars & light trucks that are OBD II compliant (including the VPW, PWM, ISO, KWP 2000 and CAN protocols) Reads and clears generic and manufacturer specific Diagnostic Trouble Codes (DTCs) Trouble codes display on the LCD, needn't the code book Scanning live data Reading Freeze Frame Data Testing I/M Reading Status Reading vehicle info Rescanning Data 2.works on all VW, AUDI, SKODA, and SEAT vehicles. it can nearly do the same work as that of a VAG1551/1552. Some of the systems the U585 will monitor for CAN OBD2 Misfire Fuel System Comprehensive components (ccm) EGR System Oxygen sensor Catalyst Evaporative O2 Sensor heater Secondary air Heated Catalyst A/C System 3.Avaliable Functions for VW/AUDI Control Unit Information Read Fault Codes Measuring Blocks Clear Fault Codes Basic Setting Adaptation Single Reading Output Tests Code Module Login Service Oil Reset Code Modes Dealership Code Set many more... Specifications: 1.Supported Systems for VW/AUDI Engine ,Transmission ,Airbag ,Instrument Cluster ,Immobilizer ,Many more...... 2.Appearance Display-Backlit LCD,128*64 pixel display. Operating Temperature- 0 to 50 Internal Power- 9v Cell External Power: 10.0 to 15.5 vols provided via vehicle battery 3.Vehicle Coverage GM '96 - Current Year (OBD-II) Ford '96 - Current Year (OBD-II) Chrysler '96 - Current Year (OBD-II) Toyota '96 - Current Year (OBD-II) Honda '96 - Current Year (OBD-II) NISSAN '96 - Current Year (OBD-II) Other Asian and European '96 - Current Year (OBD-II) New CAN protocol cars VW/AUDI cars |
very good job and you can find more in xcardiag.com
