vw golf 1.8 gl 1995- Wont start!
Changed the leads, plugs, rotory and cap. Starts most of the time but in the real cold or dampness it wont start. A mechanic changed the cold start valve but he said it may of 'shorted out' on fitting as he forgot to turn ignition off prior to fitting! I;m going to change the cold start valve agian but can anybody think of something imay have overlooked or something i should try? Please help
You want to try to narrow down why it doesn't start. A car needs 4 things to run: 1- Compression 2- Air 3- Spark 4- Fuel.</P> If the car runs good when its warm, compression is not a problem.</P> If the car has a problem with airflow, it would start hard in all temperatures.</P> It CAN be a spark problem, but the chances of it are next none. The easiest way to check spark is to remove one of the spark plug wires, stick a screwdriver into the wire, lay it across a chassis ground point, and turn the key. Have someone watch for spark.</P> Fuel could also be a problem. It takes more gas to start a car when its cold or damp out, so it could point to a weak fuel pump, or the cold start valve.</P> Thats about all I can tell you right now, I'll see if I can think of anything else.</P> I hopes that helps a little.</P> -Jason</P> |
| All times are GMT -5. The time now is 04:01 AM. |
