-   -   Syncro rabbit gti swap 2wd to 4wd (https://volkswagenforum.com/forum/general-tech-7/syncro-rabbit-gti-swap-2wd-4wd-1031/)
P_smurf Jul 10, 2006 10:36 PM
I have a friend that races his VW rabbit car. He was telling me about a swap you could do to make a rabbit 4wd. He said that you needed a Syncro Bus tranny and rear diff setup.
this is all he said about the parts that you needed.
I figured that you guys might know what he is talking about.
And info helps.
Questions i have.
Is a syncro bus that only thing that you can use the parts out of?
Will the parts out of a 1987 VW Quantum Syncro wagon work?
Is this a bolt on swap?
thanks
if you have links to swaps or info let me know
P_smurf Jul 16, 2006 04:02 PM
RE: Syncro rabbit gti swap 2wd to 4wd
come on someone has to know.
bustedupride Aug 1, 2006 01:32 AM
sorry i dont know about that but do you know if there's a difference between 85 and 83 rabbits? will a newer engine fit in an 83?
