Speedometer/ Tach Intermittent
[&:] My 1998 Jetta Wolfburg 95% of the time does not have any speedometer or tachometer. They are inop consistenly with each other. Either they both work or they are both pegged down at zero. Once in a while the needles work flawlessly untill the engine is turned off. Any body know what the problem is and if there is a quick fix?
LET me know if you get an answer
Let me know if you find a way to fix that problem my car is doing the same exact thing
