slight miss
Old Mar 23, 2013 | 05:10 PM
cowgirl05's Avatar
Default slight miss
I have a 2005 Jetta, I have 118,000 miles on it, and at 60-65 miles an hour I notice a slight hesitation in the engine. I have had the car on a scanner several times, but no one can figure it out. New spark plugs and air filter were recently installed.
Old Mar 23, 2013 | 07:29 PM
Well it will depend on which scanner was used the best one is VCDS.
Can you post any error codes retrieved from that scan?
The hesitation sound like Limp mode: What is it, what are the causes, and how to fix it for the Audi and VW TDI diesel turbo
Old Mar 25, 2013 | 05:21 PM
cowgirl05's Avatar
Hi Keith, my boyfriend used a scan tool he got from Snap On Tools. The code is a P1281 coolant temperature performance sensor which has been replaced. We plan on replacing the timing belt, water belt, and thermostat soon. I have a 2005 Jetta, with a 2.0 SOHC, with 118,000 miles on it. The engine code is BEV, and automatic transmission.
Old Mar 25, 2013 | 08:06 PM
VAG Error Code: 17689
EOBD II Error Code: P1281
Fault Location:
Fuel Metering Solenoid - Short to Earth
Possible Cause:
Wiring short to earth.
Fuel metering solenoid.
May 4, 2011 06:50 AM
Jan 20, 2011 01:48 AM
Oct 27, 2010 03:24 AM
gear_hd
Apr 14, 2008 09:51 PM
