shift knob removal 2001 VW Jetta
Old Sep 22, 2006 | 03:41 PM
d.gribble's Avatar
Default shift **** removal 2001 VW Jetta
Can anyone help me, I am trying to remove the shifter **** on my 2001 VW Jetta 1.8T. It doesn't want to twist off and I don't want to break it. I am making an 8 Ball shifter **** for it
Old Jan 25, 2007 | 04:12 PM
84xj1100's Avatar
Default RE: shift **** removal 2001 VW Jetta
I can only *** u me that it would be similar to a 2001 golf - if that is the case, in order to replace your **** there are two things you have to be aware of.
First - I believe that the **** and boot are inseperable and therefore a new boot may be in order as well.
Second - in order to get to the area for **** removal you must lift the boot (there is a plastic retaining bracket at the base of the boot that just pops out) peel the boot up to the top and along the way you'll notice a brass clip that you must remove (cut) off that holds the **** in place. Then simply lift up on the **** and it'll pop right off. You should recieve an adaptor with your new ****.
Hope this helps
Ed
bxblackout52
Jun 7, 2009 08:47 PM
sweden329
Dec 28, 2006 11:06 PM
DanHag
Dec 6, 2006 08:02 PM
BeetleGirl
Aug 24, 2006 09:36 PM
VDubGroupie06
May 27, 2006 06:23 PM
