brake caliper pistons
Old 08-14-2008, 03:56 AM
volksipers's Avatar
Default brake caliper pistons
How do you compress the rear brake caliper pistons to install new pads?
______________
volksipers24320354
Old 08-14-2008, 10:09 PM
kurtdaniel's Avatar
Member
Default RE: brake caliper pistons
ORIGINAL: volksipers
______________
volksipers24320354
Try to ask for the special tool used for compressing pistons. It is usually available at your local Autopartswarehouse store. This will absolutely save you a ton of time and aggravation.
Old 08-14-2008, 10:10 PM
volksipers's Avatar
tnx so much
Old 08-15-2008, 03:34 PM
the rear caliper pistons screw in I just used a 1/4 inch extension and welded the end to a peice of scrap metal and grinded out a small portion of it so i could hook it to a socket wench. it works great and makes it easy and cheap.
jetta 05
02-02-2012 07:46 PM
Motorology
03-17-2008 11:35 PM
onephinesuperduty
03-11-2008 07:40 PM
cristos
07-11-2007 02:09 PM
Gorkysmeg
12-01-2006 03:51 PM
Quick Reply: brake caliper pistons
