Program Monsoon VI radio in my 03 Jetta 1.8T
Hi,
I found that holding the dolby button lets me change the speed/volume setting. Does anyone know the rest of the programable functions for this radio and if so, how to access and adjust them??? |
RE: Program Monsoon VI radio in my 03 Jetta 1.8T
I didn't even know that one and I've been trying to figure it out for days! Thanks!
They also call it a volume boost, but I personally don't hear a difference. Another secret button is the MIX button. Hold that down for about 5-10 seconds and it shows you another menu. You can turn you antenna on/off, check you levels, set you volume levels, etc. Once you're in the menu you'll need to hit the Mix button to scroll through each section.
| All times are GMT -5. The time now is 02:59 AM. |
