Plugs Aren't Just For Hair: You Can Repair Tires
Old Mar 22, 2013 | 01:48 AM
Victor520's Avatar
Member
Default Plugs Aren't Just For Hair: You Can Repair Tires
You Can Repair Tires Yourself!
Plug or Patch? The debate on plugs vs patches vs both rages unending. We're here to talk about plugs. Experts have lots of opinions on tire repair. I've used plugs by themselves for years with great results and no safety issues, but others will tell you that a plug without a matching patch inside is dangerous. I can only tell you my experience. If you're not sure, take your tire to a professional for consultation.
The tire plug method of repairing tires is a mysterious thing. The first time you see one installed brings feelings of amazement and doubt. You're amazed that it held air but doubt it will last more than a day or two. The fact is that a proper tire repair will last forever. Why should you have to replace one of your tires with perfectly good tread just because a nail danced its way into your life?
For about $5 and 5 minutes of your life, you can give a dead tire a new lease on life by using a common tire plug. It's just too easy to pass up.
Never attempt to plug a sidewall! Your tire's sidewall is under different strains and pressures than the part that makes contact with the road. Plugging a sidewall can result in a blowout, so don't try it.
*Note: The NHTSA has stated that a plug is not a proper permanent tire repair.
Finding the Offending Object
Spin the tire until you find the evil little metal bit that made a certain hour of your life really unpleasant. If you're lucky, it will be a big, easy to remove nail or screw like this one. Don't pull it out just yet, though, because we want to be prepared for the next steps without making our lives any harder.
If you aren't so lucky and can't see the object that pierced your tire, you'll have to find the leak by other methods.
Mark the Spot for the Tire Repair
Before you remove the nail or screw from your flat tire, take a piece of tape and put it just below the spot where it went in. With a pen, mark the exact spot that has the nail in it. This will allow you to find the hole again once the object is out of there. It's very hard to find again if you lose the spot.
Don't worry if you forget to mark it, or if your tape comes off. You can use this method to find the hole again.
Remove the Nail or Screw to Begin the Tire Repair
Now that you have a plan to reconnoiter with the hole later, you can go ahead and remove the nail or screw from the tire. You might have to grip the nail with pliers or Vise Grips if it proves hard to remove. If it's a screw, you can just unscrew it.
Ream Out the Hole in the Tire
In your tire plug kit, you'll see a tool that looks like a round file with a handle. This is used to clean out and rough up the hole in your tire prior to plugging. Take this tool and ram it into the hole. Move it up and down a few times to roughen up the inside. You don't have to go nuts on it, a few solid pumps should do it.
Thread the Tire Repair Plug Tool
Now you finally get to play with those cute little tar-worms (the not so clean way to repair tires, but it works). Peel one of them off and thread it through the tool that has an eye on one end, like a giant needle. You'll have to pinch the end of the worm to get it in there, but it can be done. Pull it through until it is centered in the plugging tool.
Plug It to Repair the Tire For Good
With the worm threaded onto the plugging tool, stick the end of the tool into the hole in your tire. Once it's in just a little, start to really push on it so that the tool and the plug sink into the hole. It will be pretty hard to push in, but you're looking for a tight fit to hold in all that air. Push the plug in until only about 1/2 inch is sticking out. Now pull the plugging tool straight out, leaving the plug where it's supposed to be, in the hole.
If you have something to cut the ends of the plug off with, go ahead and trim it close to the tire. If nothing's handy, you can trim it later.
Now fill your tire with air to the proper tire pressure and you are 100 percent back in action. Well done, you can now repair tires!
Old May 9, 2013 | 02:52 AM
Victor520's Avatar
Member
hope it can help you
Market11
May 5, 2011 03:13 AM
Market11
May 5, 2011 02:46 AM
Market11
May 3, 2011 09:56 AM
Market11
Apr 28, 2011 03:52 AM
onecrazyfuq
Jul 28, 2006 03:21 AM
