please help me and save my life
My 1997 jetta almost drove my crazy and killed me several times...So please help me to find out what is wrong with the damned car.(I checked with mechanics but they told me nothing was wrong.
It started around 1 year ago. When it was raining, I can not start my car. I can hear the sound "tu tu tu tu..." which mean the engine was trying to start. After 3-4 times try, the car can be started. But if I stepped the brake, the car automatically shut down and I need to restart again. I took my car to the garage, they can not find anything wrong. The same story happened several times. So I consulted my friend who suggested me to change to coil and spark plug and I did it. And I never got the problem for 4 months even when it was heavily snowing. These days, it is raining a lot in my town and the horrible experience come again! The difference is that there is no problem for me to start my in the raining days. But once I started and drove for 2 minutes, the car automatically shut off and can never re-start again. One time I was under the traffic light!! The worst thing is the car can be restarted by jump start and run well when the rain stop, and the mechanics can never dig out what the ****ing problem is! Everything is fine, they told me. But I will die in my car. Please give some advice and save my life |
RE: please help me and save my life
Loose battery cables?
my old car wouldn't start sometimes because of loose battery cables, it would always start under a jump though. maybe when you changed your coil and plugs you tightned the cables and now after time they have come loose again, check it out, its an easy fix |
Yea I'm with him...seems like a loose terminal..did you ever try doing an alternator check, or even changing the battery??
That is one faulty VW auto parts, if ever you find it... Though I do agree that it could be a loose cable... Try changing your cable and replace also your mechanic... What kind of mechanic that would tell you there is no problem if your VW problem almost cost your life... Goodluck...
more than likely a ground problem. i doubt it would be the battery although i wouldnt put it past.
Sounds like there's moisture in your distributor cap, this has happened to me a few times. Either wait for this to dry out and try again or take the cap off and dry with a hairdryer. After you get it running again, I would spray it with an ignition sealer to block water from getting into it in the future.
| All times are GMT -5. The time now is 04:48 AM. |
