ok is the head cracked or the core out.......
Old Jan 22, 2008 | 12:55 PM
xmextream's Avatar
Default ok is the head cracked or the core out.......
ok i had a friend do a check up on the engine. he said he saw a hose not connected. so he hocked it up and then i started the engine and smoke was pouring out of the heater vents and exhaust.also had the cent of anti freeze and gas. the down fall is that my dad thinks its the heater core. but my friend said that it was a cracked head. so if anyone can tell me the problem it would be nice.
Old Jan 23, 2008 | 02:46 PM
Smokin Dog's Avatar
Default RE: ok is the head cracked or the core out.......
Smoke wont pour out the heater vents if you have a
cracked head, it would be a heater core cracked.
On the other hand a cracked heater core wont cause
smoke to pour out the exhaust, that would be antifreeze
entering the cylinders, via....blown head gasket, cracked
engine block, or cracked head.
Summary.....you most likely have a bad heater core
and a engine problem.
Old Jan 23, 2008 | 08:31 PM
xmextream's Avatar
hey man thanks for the help. if you can give me a little mre info. about it that would be wonderful. would the core cause a mix of oil and antifreeze to go into the engine block. also would that be the smoke out of the exhaust. thanks for you help man....
Old Jan 24, 2008 | 10:55 AM
Smokin Dog's Avatar
The heater core leaking, would be antifreeze only. it would cause smoke out the vents, and could drip in the floor
or under the hood, depends on where it's located and where
the drain is. It has nothing to do with engine oil in any way
what so ever.
A mix of oil and antifreeze inside the engine block, would
be caused by a crack in the head, a crack in the engine block, or a blown head gasket. To repair this would mean
tareing down the engine and investigating all the parts,
You could install a can of radiator stopleak made by
Solder Seal, it's a silver powder and works great. Install it
in the radiator and top it up with antifreeze and run the
engine for a long while, but be sure the oil is good. You
should change the oil anyway. I've done this and got as much as 5 years good engine time out of it with no problems,
The silver powder goes into the crack and seals it, if it's a
head gasket it wont work as well. AND THISIS NOT A CORRECT REPAIR, BUT CANPROVIDE SEVERAL MILES AND YEARS OF SERVICE AT ALMOST NO COST.It could also
seal the heater core for a while. But don't use just any
kind of radiator stop leak, some of it cloggs up all the
works and then you got a problem.
The smoke out the heater vents should be white or like
steam. that would be hot antifreeze.
The smoke out the exhaust........ you didn't say what
color it is.
BLACK would be gasoline or fuel too rich.
WHITE would be antifreeze getting into the engine and
burning, then going out the exhaust. IF antifreeze is in
the engine oil, it's also getting into a cylinder and being
burned when the engine is running.
BLUE would be engine oil burning.
HEAVY THICK WHITE would be automatic transmission fluid burning. This would be a lot of white smoke............ antifreeze burning would almost look like steam and it would
also go away after a short time into the air.
Old Jan 26, 2008 | 09:57 PM
xmextream's Avatar
hey thanks again.. the color of the smoke was white......not sure if there is any problems yet i found your information very useful. i hope maybe some time i will find time to fix the car asap.....thanks again man......
Old Jan 27, 2008 | 11:01 AM
Smokin Dog's Avatar
Your welcome......and GOOD LUCK!!
barkinspyd3rs
Sep 19, 2010 07:49 PM
phatshop
Apr 20, 2010 09:10 AM
VegenZ
Apr 13, 2010 09:19 PM
dbotteicher
Dec 22, 2009 09:52 PM
maverick9611
Jan 5, 2008 05:33 AM
