-   -   oil pressure sender install (https://volkswagenforum.com/forum/general-tech-7/oil-pressure-sender-install-320/)
shapiror Nov 20, 2005 01:43 PM
hello,
i am having problems with my oil pressure light in my '02 Jetta GLS 1.8T. i'm going to replace the oil pressure sender/sensor as a first solution. the problem is, no one i have talked to knows where it is located. does anyone know where the oil pressure sender is located so i can replace it? also, does the oil need drained before I replace the sensor?
thanks,
randy
