need a pin layout for 91 jetta radiator fan
Old May 11, 2007 | 07:15 PM
jakejetta's Avatar
Default need a pin layout for 91 jetta radiator fan
hello, i'm trying to troubleshoot the real reason why my radiator fan is not coming on. i originally wanted to install a manual switch to turn it on when i wanted to, but that obviously wouldn't work if the fan motor is burned out. i bypassed the relay, connecting the wires from pins 30 and 87 together, and i get nothing. i tested the pins with a voltmeter, and got a small voltage that slowly drains upon putting the multimeter in there. i have confirmed that there is 12V going into pin 30, so it should turn on the fan when you connect the wires from pins 30 and 87. so now i'm thinking either the fan is burned out, or someone else tried to troubleshoot and mixed up the wires at the fan.
does anyone have a pin layout for a 91 Jetta radiator fan? thanks.
Old Sep 1, 2007 | 03:20 AM
kurtdaniel's Avatar
Member
Default RE: need a pin layout for 91 jetta radiator fan
There is a temperature sensor that signals the fans to come on when the cooling system gets warm. Your coolant sensor may be faulty or disconnected.
More help from here http://www.2carpros.com/topics/fan.htm volkswagen radiator buy. Good luck.
herbherb
Feb 12, 2010 02:17 AM
Odins Les Paul
Feb 9, 2010 08:21 PM
jetta96gls
Oct 23, 2009 06:56 AM
gypsypirate
Feb 8, 2008 01:07 PM
airborne21
Dec 1, 2007 10:31 AM
