1969 Bug Horn Wiring
Old 08-06-2019, 05:34 PM
thebunns's Avatar
Default 1969 Bug Horn Wiring
I have watched all the videos I can find & all seem to be describing a solution to someone who already knows it. I have the complete wiring diagram but it does not go into detail on the horn ground path. I can get continuity from the horn ground wire at the horn to where it's soldered onto the steering wheel bearing. I get no continuity from the wire in the center of the steering column to ground. How is that wire routed & where is it terminated?
eljakeo22
09-02-2015 04:59 AM
Brandon
07-04-2008 09:49 AM
lisaintherain
12-07-2007 10:15 PM
vdubbin95
06-15-2007 10:39 AM
spitvalve4
03-17-2007 11:58 AM
Quick Reply: 1969 Bug Horn Wiring
