My golf is posessed...
I have a 2002 TDI Golf. Recently it has been acting crazy, and the following has been happening.
-Rear doors randomly unlock and lock, one at a time. (Ive noticed the rear driver side has been unlocking when I come to a stop, and relocking when I accelerate, passenger side is less predictable) -When I turn the car off, sometimes (maybe once every 20 times I turn the car off) the interior light does not stay on, if this happens when I restart the car the odometer resets. -The brake light will flash and the car will chime at me roughly 3 or 4 times, then go off and back to normal. (this will also reset the odometer) -The car randomly clicks sounds like a turn signal and/or hazard lights but slightly faster, yet none of the lights are active neither on the dash or the signals themselves. It seems like I may have a bad ground somewhere, but I have no idea where to even start. If anyone has any solution to ANY of the problems above, info would be greatly appreciated. Thanks, Shawn |
RE: My golf is posessed...
Just talking...and not knowing for sure, it does sound like
a bad ground. You could easily make another ground, just use a wire and fasten it to the main body of the instrument cluster and then find a metal place on the car body, if that helps some then add some more ground wires else where, trying to find the factory ground could be a night mare. |
