MultiDi@g Access J2534 not start..
hello just purchased MultiDi@g Access J2534 from http://www.diyobd2.fr/wholesale/multidig-access-j2534-obd2-interface.html Multi-Di@g Access J2534 Pass-Thru OBD2 Interface my order nr: u212082417952 the program multi-diag access works fine but if I will use the program action workshop ati then that program will not start via shortcut on desktop or must I activate this in the menu off multi-diag acces? Does anyone know ... how to solve it ?
Is there no instruction manual with it, ask the seller?
If the desktop short-cut doesn't work uninstall then reinstall the software or check it properties. |
good!!!!!!!!!!!
Originally Posted by ssali
(Post 58863)
hello just purchased MultiDi@g Access J2534 from Multi-Di@g Access J2534 Pass-Thru OBD2 InterfaceMulti-Di@g Access J2534 Pass-Thru OBD2 Interface my order nr: u212082417952 the program multi-diag access works fine but if I will use the program action workshop ati then that program will not start via shortcut on desktop or must I activate this in the menu off multi-diag acces? Does anyone know ... how to solve it ?
you should according to the instruction, send them the ID then they can give you keys i have one technic link for reference Multi-Di@g Access J2534 Pass-Thru OBD2 Device Technical Service i followed this and done it not really difficult:D |
| All times are GMT -5. The time now is 03:55 AM. |
