Intermitent Heat
Old Jan 25, 2007 | 01:09 PM
jeepwillies's Avatar
Default Intermitent Heat
So I get into my Westy the other week and the coolant light is flashing. I fill the resivoir and the light goes out. Turns out my head gasket is leaking a bit when the engine is cold, will fix later. So I continue to fill it every so often.
Today when I get in it, the light is blinking, so I fill 'er up. Only now the light does not go out and there is no heat from the vents. Well actually there is heat for a minute, then no heat and still blinking light.
Any suggestions?
BTW its an 87.
Dave
Old Jan 25, 2007 | 05:24 PM
Default RE: Intermitent Heat
So i went out at lunch and the system sucked the resevoir dry, the light is out and the heat is back.
Air lock I supose keeping the system from grabbing more collant from the resevoir or the thermostat did not open.
Thanks,
D
viggo olesen
Mar 7, 2016 07:26 PM
sparrow
Sep 24, 2009 11:49 AM
rb6493
Jan 5, 2008 05:44 PM
behrll80
Nov 21, 2007 10:40 PM
Berrie
Nov 7, 2007 06:24 PM
