How to program your key fob.
Old 03-28-2012, 02:17 AM
Belmonter's Avatar
Default How to program your key fob.
If I have to take the second fret for my S60, I have one of Rufe and then my agent must encode car.Im said it was important to a bar code that comes with a key to get because this is what they use the software to get the key to read in cars instead of receiving a signal fromt fob.SO answer is what Im saying the most important representative job ..
  #32
Old 04-02-2012, 12:55 AM
applegot's Avatar
You have to take the keys to a local dealer that Nissan. They will give you an estimate on how much it costs. Usually expensive, but in some cases they are not. I work in a former page, and many older vehicles are still expensive. The same should be programmed fob SO unless you have installed the system yourself.
  #33
Old 04-09-2012, 01:42 AM
coqwwpor's Avatar
Originally Posted by purplemoon
I just have to say ... THANK YOU THANK YOU THANK YOU ...
you have just saved my life
and us a lot of money
Although a bit exaggerated, but the feeling is very sincere
  #34
Old 04-13-2012, 01:56 AM
coqwwpor's Avatar
Originally Posted by niki11
VW key fob has two parts. First one a transmitter or a remote and secondly a mutable code transponder along with main key. Initially for programming you have to make sure that you select the proper remote. select the required frequency. For programming there are two parts. first to operate the door and second function is as car immobilizer.
Good, thanks for the reply, so useful
  #35
Old 04-18-2012, 11:40 AM
Jimmijackson's Avatar
its very good information and thank u so much for your information
  #36
Old 08-09-2012, 07:02 AM
anie's Avatar
Put one key into the ignition and turn it on. Don't start car.
Using the second key lock the car manually outside.
Press unlock once and wait a couple of seconds.
Then press lock once.
Manually unlock the car and remove the key from the ignition.
Now test your key fob.
  #37
Old 08-19-2012, 01:19 AM
aynaa's Avatar
Well this is good information i was waiting to know this process.
  #38
Old 08-27-2012, 04:23 AM
miraaa's Avatar
  #39
Old 08-30-2012, 01:15 AM
seo.o1object's Avatar
ProgramYourRemote.com provides free programming instructions and procedures for automotive keyless entry remote fobs for all makes and models of cars
  #40
Old 09-09-2012, 02:09 PM
anjumafaaq's Avatar
Default reply:
I just got my car and the dealer didn’t have an extra spare key for me…so he gave me some other VW’s key+FOB and told me to get he key part recut at the VW dealership and to reprogram the FOB part myself to save $$$.
Quick Reply: How to program your key fob.
