drivers side door won't unlock
Old Jul 15, 2005 | 02:39 PM
speedtrap's Avatar
Default drivers side door won't unlock
Anybody have this problem before and know what needs fixing?
The drivers side door on a 97 Passat will not unlock. Keyless entry works all other doors but the drivers door still remains locked. you can't open it from the inside or outside. Is there a control module in the door that may need replacing?
Old Jul 28, 2005 | 01:14 AM
rossiross's Avatar
Default RE: drivers side door won't unlock
Sure thing man, there is an electric motor in the door hooked up to your lock. I installed keyless in an older VW and the push bar would come off. First thing take the door panel off the door. Check the motor to see if it’s moving. Follow back from the lock itself to see if the plastic or metal is broken anywhere in the line.
RobM
mohamed
Apr 16, 2012 02:05 PM
Oct 29, 2010 02:43 AM
kailas
May 13, 2009 08:39 AM
Castro27
Feb 5, 2009 07:52 PM
Schmitty
Jul 31, 2007 04:30 AM
