Diesel additive?
Old 12-09-2006 | 11:08 AM
Ricky's Avatar
Default Diesel additive?
Is there something I am supposed to be putting in my diesel engine now that it is winter? I heard that there was, but I don't know what it is. Any help would be appreciated.
Old 12-09-2006 | 11:58 AM
finbar06's Avatar
Default RE: Diesel additive?
depending on where you live there are a couple of conditioners or water sepaerators that you could try, keep fuel filter clean and replace or drain water separator regularly,try a local diesel truck stop they usually have what you need.
Old 12-12-2006 | 01:10 AM
itcooksvw's Avatar
My name is Dave and I'm a Diesel Tech for a Ford Dealership in Florida,and once upon a time in Tennessee. Diesel fuel does need certain additives which are already added to most northern fuel supplies at the stations. These are called winter blends. A small amount of additive is OK as long as you don't put to much in. There are lubricity additives (lube up the injectors) and cetane boosters (cetane is to Diesel what octane is to Gasoline). Cetane will make it run with less smoke and easier starts. lubricty additives prolong injector life.
beeker406
11-09-2007 03:59 PM
Paul
08-22-2006 08:53 PM
DABNE
06-05-2006 05:45 PM
dieselwgn
01-16-2006 04:30 PM
James
12-06-2005 08:57 PM
Quick Reply: Diesel additive?
