Volkswagen Family Parts
Old 10-02-2017, 08:04 PM
bdlcalvin's Avatar
Default Volkswagen Family Parts
The phone control module on my 2012 Bentley Continental GT apparently failed and needs to be replaced. When I pulled the VAGCOM fault codes this is what I got:
Address 77: Telephone (J412) Labels: 3C8-035-730-A.clb
Part No SW: 3D0 035 730 A HW: 3W3 035 730 A
Component: Telefon 010 0422
Revision: -------- Serial number: 35909603107760
Coding: 020002010100010000000000
Shop #: WSC 00083 790 00191
ASAM Dataset: EV_UHVPremiPhaet A01002
ROD: EV_UHVPremiPhaet.rod
VCID: 1A3BA7EF1DA6D79664-804E
1 Fault Found:
13893632 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 2
Reset counter: 61
Mileage: 44257 km
Date: 2017.08.09
Time: 10:42:09
What's the difference between the SW part number and the HW part number? When I looked up the SW part I got a control module from a latest generation Phaeton costing about $900, but when I went to Bentley they wanted $4700 for what I'm guessing is the HW part. Does anyone have any idea if the SW part and the HW part would be interchangeable? I know Volkswagen/Audi/Bentley share a lot of parts and I'd rather not pay $4700 for something that should cost no more than $900...
Thanks in advance!
Old 10-03-2017, 05:23 AM
VAG Error Code: 16387/16640/1048580/131586/13893632/0628/10810/1539/0142/0462
EOBD II Error Code: U1400
Fault Location:
Function Restricted due to Insufficient Voltage - Intermittent - Confirmed - Tested Since Memory Clear
Possible Cause:
System Malfunction.
Battery Voltage too Low.
Fuse(s).
Possible Solutions:
Check/Replace Fuse(s).
Check/Replace Battery.
Check/Replace Generator.
Special Notes:
This Fault Code is a note which normally indicates a temporary Low Voltage Situation and unless it occurs regularly it shouldn't be of concern.
Old 10-03-2017, 01:47 PM
bdlcalvin's Avatar
Thanks for the information. I took the car to Bentley and they said that it needed a new module. I spent the entire weekend running a battery of tests to see if the batteries were at fault including testing with my other car's relatively new battery and had no luck. I checked the fuses and still no problems there, so I'm guessing either it's a wiring issue or a genuinely dead module. I'm curious if it's possible to exchange the SW and HW parts?
Fault Location:
Possible Cause:
System Malfunction.
Fuse(s).
Possible Solutions:
Special Notes:
2012 Bentley Continental GT 6.0L W12
2008 Audi A8 4.2L V8
Old 10-04-2017, 06:08 AM
I see you've asked about this.
Exchanging SW and HW Parts?
herbie99
03-25-2009 11:32 PM
astyleinc
09-21-2008 04:59 PM
pray4surf
08-17-2008 11:12 PM
blackturbo2000
08-17-2008 11:10 PM
psykodoc321
05-07-2007 10:52 AM
Quick Reply: Volkswagen Family Parts
