Check engine light on and cars run fine...help....
can someone give me some advise to what these codes mean and what needs to be replace with these codes?
i have a 2001 golf 2.0 the check engine came on and i pull the codes and here they are 1. P0606 ecm/pcm processor 2. P0261 cylinder 1 injector circuit low 3. P0267 cylinder 3 injector circuit low 4. P0270 cylinder 4 injector circuit low 5. P0264 cylinder 2 injector circuit low 6. P0445 evaporative emmission system purge control valve circuit shorted 7. P0418 secondary air injection system relay A control cirsuit note: i just replace the alternator about 2 weeks ago. at that time the check engine was not on. any help is appreciated. thanks ! |
| All times are GMT -5. The time now is 07:06 AM. |
