cannot open door on eurovan
cannot open passenger door on 2002 eurovan. both outside and inside handles do not function. i know to repair the outer handle, but since inside handle does not function getting the door panel sounds problematic if not impossible. are there any secret tricks or am i screwed? why both broken?
aggressive german houseguest. "i vill open this door !!!!!!" IS ANYBODY LISTENING?????? HELP!!!!!!!!!!!! |
dead door
Have you tried pulling the speaker in the door (which you have to do to remove the door panel) and using something like a slim jim to open the lock mechanism? That may be your best bet in opening the door if you can get to the lock and open it. or is the lock itself broken in the shut position?
