a/c switch problem
I have a 98 Jetta GL. Both lights on the A/C dash switch have gone out (not at the same time). First the A/C on light went out with no other symptoms and recently the recirculate light went this time it took the whole A/C with it. All I get is hot air and it seems the compressor is not cycling. A/C fuse ok, no voltage at compressor pin. Suspect it is either the A/C switch or the A/C relay. Anyone else go through this?
