boost controler
Old Sep 24, 2005 | 01:37 AM
1lowgli's Avatar
Default boost controler
i was installing a manual boost controller on my 2005 vw gli, the first time i started it the check engine and traction control light came on. i fixed that problem, but when putting a boost controller on do you have to flash the computer to allow it to accept the high volumes of boost. After pushing about 12 to 14 pounds of boost the comp. shut all the boost off and i cant be having that. if any one knows what i can do to fix the problem please let me know i want to up the boost to around 25
Old Sep 25, 2005 | 03:27 PM
Jsd's Avatar
Jsd
Default RE: boost controler
You shouldn't have to flash your computer for boost.
Though I dont' recommend 25psi, unless you built the car
for that application.
I notice a lot of you guy's fail to
mention whether or not it's a stock turbo setup.
List your mods or lack of, you can't give a decent response
for an unknown system.
Old Sep 26, 2005 | 07:50 PM
1lowgli's Avatar
thanks for the help, i dont really have any mods done right now except for the appearance of the vehicle but i did find out that i do have to flash my computer to allow more boost and my tech has already ordered the program to do so. But thanks for the response
Old Sep 27, 2005 | 03:37 AM
Jsd's Avatar
Jsd
Yea I just realized I misread your original post.
I also suppose you have large injectors in there
already if you can push 14psi.
It's all about air/fuel, which in all new cars is
controlled by the computer...meh. Might wanna
consider finding a local guy who does tuning
for VW turbo's, base profiles are great but to get every
ounce out you're going to have to tune it a couple times
to find the right spot that your turbo loves.
btw I don't know if I mentioned this already but
when you crank that boost way up, watch your tranny
keep an eye on tranny temp (fluid color as well)
with gauge or diagnostic tool.
Old Sep 27, 2005 | 04:25 PM
patrick's Avatar
Administrator
is there a waste gate "trick" to up the boost a little?
Old Sep 28, 2005 | 04:15 AM
Jsd's Avatar
Jsd
Not to my knowledge. It's simply to regulate the
amount of exhaust gases into the turbo so I don't
see how there would be any "tricks".
More exhaust, more boost,
-Jeff
dubalicious
5
Apr 24, 2008 04:50 PM
Randompassatguy
Sep 27, 2006 04:25 PM
freekie_deaky
Dec 30, 2005 06:18 PM
racemegti
Nov 1, 2005 03:27 PM
1lowgli
Sep 23, 2005 06:54 PM
