-   -   airbag (https://volkswagenforum.com/forum/general-tech-7/airbag-420/)
bugnutz Jan 1, 2006 02:59 PM
airbag
To replace the ignition switch on my 1993 Cabrio, I had to remove and reinstall the airbag. Before re-installing the dash, steering column, and airbag, I tested the ignition switch because it still "felt" a bit odd. Ignition worked properly so I disconnected the battery, went to lunch, came back and put the airbag and everything else all back together. Now both airbag lights are on. I've triple checked all my connections, the airbag computer must have set the fault code when I test started the car with out the bag in place. How do I reset the airbag lights or clear the code - help!
Jsd Jan 1, 2006 06:18 PM
RE: airbag
As far as I know you can do it with a diagnostic tool. Dealers use them, other than that, I have no idea.
-Jeff
