97 jetta no head lights
my sis has no head lights unless you pull back on the high beam arm for flashing people..
tested light bulbs out of the car and they are fine suspect parking brake switch or loose wiring to head light switch any ideas or a decent wiring diagram would be great Thanks for your help [&:] $cott |
RE: 97 jetta no head lights
If they work when you pull back on the leaver then
the bulbs and wireing will be good. Sounds like the relay that changes from dim to bright isn't working. |
Thanks Smoking dog you are my hero
