-   -   86gli distributor (https://volkswagenforum.com/forum/general-tech-7/86gli-distributor-11335/)
snikwah Mar 28, 2009 07:07 PM
86gli distributor
i have an 86 jetta gli that has the small (10mm) rotor shaft, and have access to older vacuum advance dist. with the larger shaft(14mm?), does anybody know if the gears on the two dist are the same if the shafts are a different size?
