2001 passat led instrument panel lights out
I have a 2001 vw passat, the illumination lights for the instrument panel for the heater and fan controls is out. Is this a light problem or could I possibly have a fuse out? The indicator lights for the right and left vents are also out, any connection?
Thank You |
RE: 2001 passat led instrument panel lights out
Pull your fuse panel and check the
fuses that are for the instrument lights to see if they are burnt out. I doubt it's a wire issue being a 2001. Just start with checking the fuses and work your way to the actual panel itself and check all the connections. |
| All times are GMT -5. The time now is 12:28 AM. |
