-   -   2 Rookies of the VW world need HELP! (https://volkswagenforum.com/forum/general-tech-7/2-rookies-vw-world-need-help-6676/)
dadandson Oct 20, 2008 10:52 PM
Anyone,
My son and I are trying to get an old (1960 something) sandrail to run. The rail has been sitting untouched for approx. 10 years and it was running well when it was parked. We have put in new plugs, wires, oil, etc.. and are now in the process of trying to manually turn the motor over to break the rings loose withoutscoring the cylinders. The problem is that it isn't turning over using a breaker bar aand socket on the large pulley. We have pulled the plugs to reduce compression but this has not helped. Can we push it and pop the clutch?Are weforgetting to do something? Should I just shoot it?
Thanks,
dadandson
Jrailer Oct 21, 2008 08:54 AM
RE: 2 Rookies of the VW world need HELP!
put some oil in the cylinders and let it sit for a day first
dadandson Oct 21, 2008 06:51 PM
Thanks, we'll give it a try and let you know.
dubalicious Oct 23, 2008 06:32 PM
and if that dosent work... shoot it ha ha ha :)just joking
