1999 Golf - Heat issue
Hi,
Dam cold here in CT. When outside temperature is above 40 degrees , thermostat stays at 190 all the time. If any colder the thermostat stays down around 120, and if you use heater it goes lower. Doesnt make for a very warm commute. Will never go above 140 even after 1 hr commute. Any suggestions? Thanks |
RE: 1999 Golf - Heat issue
Sounds like you have a great cooling system. If it's working that good and nothing is wrong, you might play the
ole trucker game. Use a good piece of card board and slide it in front of the radiator, but be sure it's only about 1/2 covering the radiator, then after you drive it you will be able to tell if you need to cut the cardboard down smaller or get a larger piece. just don't block off all the air flow and be sure to watch the temp gauge for over heating. |
| All times are GMT -5. The time now is 02:32 AM. |
