1997 Jetta GLS electrical problems!
Old Apr 5, 2008 | 12:10 PM
missaba's Avatar
Default 1997 Jetta GLS electrical problems!
So a few days ago I bought a '97 Jetta GLS.
Since I got it, I noticed a few problems with the power windows and power locks.
Problem #1. Windows won't go down! The only windows that DO go down are the Front Right hand side window and the Rear Left hand side window. The sunroof works perfectly. I don't hear a motor chugging or the windows shuddering when I press the button so I'm guessing it might be a fuse problem but I'd like some opinions on that first before I go messing around.
Problem #2. Power locks don't work AT ALL. When I turn the key on the outside of the door, I hear a motor turning but nothing happens. Same when I press the button on the panel under the radio....motor starts chugging but no movement on the locks. The alarm does work though. If I lock my door from the outside and someone else tries to open a door, the alarm goes off.
This, as I'm sure you all understand, is quite annoying. Are these problems that I can fix myself at home? Or should I save up some moniez and visit a mechanic?
Thanks!
Old Apr 7, 2008 | 12:02 PM
bagel's Avatar
Default RE: 1997 Jetta GLS electrical problems!
It's prolly window tracks...my plastic clips on my passenger window broke off on the track and now my window won't go up or down. As for locks, that's electricla I would think. I have less than zero experience with locks and such, I usually let professionals deal with that. Fuse or elctrical is what I would think it would be.
Brennanc1
12
Feb 25, 2012 12:39 PM
Jetta98
Oct 9, 2010 04:02 PM
JJeffers
Oct 8, 2010 07:23 AM
Jetta98
Oct 6, 2010 11:46 AM
jgn118
Jun 3, 2010 02:34 PM
