-   -   1990 jetta will not turn over (https://volkswagenforum.com/forum/general-tech-7/1990-jetta-will-not-turn-over-688/)
davepa Apr 6, 2006 08:56 PM
1990 jetta gl will not turn over once the outside temp. is above 60 degrees and the engine has warmed up. Once the car sits for about 20 minutes the starter will spin as normal. What is heating up in the circuit causing this to happen? Is there a relay associated with the starting system that may be causing the problem? Not sure where else to look. Any help welcomed! thanks Dave
JDM_BONES Apr 19, 2006 02:43 AM
RE: 1990 jetta will not turn over
I hope you find out, because I am having the same problem.[&o]
davepa Apr 19, 2006 11:17 AM
It seems that many people have the No-spin starter problem, but as of yet no one has come forward to say how the problem was corrected. I will have to find another forum that is a bit more inclined to try to repair problem areas. Regards
JDM_BONES Apr 20, 2006 12:02 AM
Well Dave if you find a better VW forum let me know...I am also looking for answers...
