-   -   02 GTI transmission problem (https://volkswagenforum.com/forum/general-tech-7/02-gti-transmission-problem-30997/)
sxb86 Feb 25, 2011 01:09 PM
I have an 02 GTI with and automatic transmission. When i start the car, and put it in drive it doesnt shift into second gear right away. If i ride around for a few minutes, and keep accelerating lightly and stopping it finally shifts in gear. But after that it shifts fine all day. It only happens when the car sits for a long period of time.. say like overnight. I live in FL so its not because of the cold weather. What could that be?
Jinpp.Liang Mar 17, 2011 09:13 PM
PDF(Portable Document Format) is a great format to store and share data and also is a type of file that does not depend on your computer’s operating system. PDFs are great for archiving, printing, file sharing because they are compact, universal. However, PDF is not a word-processing file. They don’t like DOC that can be used for composing and editing. sometime you might be in this situation that you need to fill out a form that have been saved as a PDF. Obviously, you may need to convert PDF to word mac in the Mac OSX operating system. Is there any method for pdf to doc mac? fortunately, this article introduces a way which can change PDF to doc on mac in your Mac OSX operating system.
The easy way to convert PDF to Word Mac
PDF Converter for Mac is a ideal choice for pdf to word mac. You can convert pdf to word for mac quickly and accurately. And then you can edit or compose the content just like on the Word file in the table of PDF file on your Mac .With the pdf to word converter mac.
The feature of PDF Converter Mac
1)Good Preservation
2) High Efficiency
3)Encrypted PDF Files Conversion
4)Flexible Options
5)Easy to Use
Tags: pdf converter for mac, pdf converter mac, convert pdf to word mac, pdf to word mac, pdf to word for mac, pdf to word converter mac, mac pdf to word, pdf word mac, convert pdf to doc mac, pdf to doc converter mac
