body help
hey guys, i don't know if this is the correct place to ask but what grit of sand paper should i use to sand down my '65 beetle?
thanks -chris |
RE: body help
are you going to bare metal or just like half way down???
tony |
RE: body help
just shave it enough to re-paint
RE: body help
you will need a fine grit like 250-400 grit. all you will need to do i rough it up and that paint is not all to hard i would imagen.
tony |
RE: body help
i'm gonna get a air spray gun and such to use, i also have a few places i need to bondo cause rust is taking its toll, maybe take more paint off in those places and stuff.
RE: body help
you do relize that what you want to do is a bigger project than you think right???
the spry gun will work fine in all but you will need to be very particular with it. and in the bondo place it needs to be down to the bare metal. tony |
RE: body help
yea i figured about the bondo, and if i mess up with the paint, i'll just sand it down again, i'm trying mot to spend a fortune on this car, i picked it up for $800 from some lady, it also has some linkage problems, i don't know if i really want to get in there right now lol
RE: body help
linkage for what... i could be an easy fix.
tony |
RE: body help
to the tranny, hard to get it in gear sometimes, the old VW's have skidplate/floor boards, i might want to remove that sometime
RE: body help
yha if you remove those it should open up alot more to you to see
tony |
| All times are GMT -5. The time now is 03:54 AM. |
