Detailing Discuss detailing your ride inside and out here.
Need Help with interior cleaning.
Old 11-30-2006, 07:48 PM
heavenly_blade101's Avatar
Default Need Help with interior cleaning.
Hello,
I have a very filthy car. I need help with a few things. when I vacuumed the floor it didnt get everything out. I went over it about 5 times and still nothing. I also was wondering if it would be alright to put armor-all on a Q-Tip to clean all the dust from the vents. Thanks for the Help!
Old 12-05-2006, 11:09 AM
Joelzy's Avatar
Default RE: Need Help with interior cleaning.
not sure about the carpet, maybe use a shop vac? and for the vents, i dont see why not as long as it doesnt drip and run too much, even then i doubt itll hurt.
Old 11-10-2007, 07:33 PM
The best thing I've found to clean vents and down in cracks is
a new small paint brush like 1/2 inch wide.
Old 11-16-2007, 08:00 PM
spray all purpose cleaner on the carpets then scrub with soap....let sit for like 5-10 min....then vacume...that should do it
Old 08-16-2008, 11:15 AM
Ye I need Something with the carpets to, Filthy As can Be.
Old 08-17-2008, 10:51 PM
I think i might try that the Paint brish ...
  #7
Old 08-18-2008, 11:17 PM
bagel's Avatar
To clean AC/heat vents use a cue tip with a dab of water. To clean the carpets just use regular carpet cleaner and use a scrub brush
  #8
Old 08-19-2008, 08:02 PM
But what do you use to get stains out from the ceiling?
  #9
Old 11-22-2019, 06:47 AM
jookils's Avatar
heavenly_blade101
11-22-2019 06:46 AM
sonax
02-28-2014 08:54 AM
TurboBug
10-15-2012 10:57 AM
taperedmind157
02-15-2009 04:04 PM
Quick Reply: Need Help with interior cleaning.
