Concept & Rumor Mill Heard you heard? Have you seen? No? Come on in.
Diesel additive
Old Jul 11, 2007 | 07:21 AM
beeker406's Avatar
Default Diesel additive
Ok, so i'm new here. However I'm not new to Diesels. I have also owed 3 VW rabbit pick ups, two of them i droveuntil the body was gone, then pulled motor used it again. Here is my question: Do you really get better mileage with a diesel engine if you add TWO-Stroke oil to the fuel? There has been much debate about this around my shop. One old time driver swears he gets much better mileage when he dumps in a quart of USED engine oil every fillup. Still another swears by TWO-Stroke Oil. I understand that the lubrication isn't there like it used to be in the Diesel, but come on! Is this Really a good idea? This sounds like a Mythbusters episode to me, but what do I know.
Old Nov 9, 2007 | 03:59 PM
Smokin Dog's Avatar
Default RE: Diesel additive
I think they are pulling your leg, is one longer than the other?
The used engine oil would add dirt and whatever else is in it ,
the two stroke oil would not help any at all. Diesel fuel is nothing
but low grade kerosene with a small amout of engine oil added
for lube of the pump. Adding too much oil can burn out the
injectors and carbon up the engine causing less power.
Ricky
Dec 12, 2006 01:10 AM
Paul
Aug 22, 2006 08:53 PM
DABNE
Jun 5, 2006 05:45 PM
dieselwgn
Jan 16, 2006 04:30 PM
James
Dec 6, 2005 08:57 PM
