Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Battery Question
Old Jan 1, 2008 | 11:30 PM
mikebandw186's Avatar
Default Battery Question
This has probably been asked many times before, but how much wattage can you run from a stock battery? i have a 450 watt amp hooked up to the speakers, and i want to put a 1000 watt amp and a sub in.
I'm wondering if this will kill the battery?
And would it be logical to then run another battery with one of the distributor blocks or whatever will charge the second battery?
Old Jan 11, 2008 | 07:19 PM
Smokin Dog's Avatar
Default RE: Battery Question
The 1000 watt amp is out put, you have to see what
the current draw is on the amp, it will be a lot less, I
doubt it will hurt you at all, unless you play the system
while your parked and the engine off, and then it would
take a few hours.
Old Jan 11, 2008 | 10:54 PM
thanks for the help kind sir
Gewing4
Sep 25, 2011 12:03 PM
sknyppy
Feb 9, 2007 12:20 AM
redoo
Jul 31, 2006 11:39 PM
exojj
Feb 4, 2006 08:21 PM
kirsty willett
Dec 20, 2005 03:13 PM
