-   Audio/Visual Electronics (https://volkswagenforum.com/forum/audio-visual-electronics-9/)
-   -   2002 Passat Radio (https://volkswagenforum.com/forum/audio-visual-electronics-9/2002-passat-radio-12281/)
WinnebagoVW Jul 6, 2009 08:22 PM
2002 Passat Radio
I have a stock Monsoon CD/Radio/Tape player. A few quirks started happening within the last month. The volume on Max is not loud at all. If I reduce the volume to Min, I cannot turn it up unless I turn the unit off and then on again. The balance and fader are not working correctly. The dealership told me I needed to replace the unit. Unfortunately, I really don't trust them, but they may be right. Is this common? Being a first time VW owner, I don't know. I was told that it may be as simple as a fuse replacement, but to watch that I don't screw up the radio code.
Any thoughts or help would be appreciated.
Thanks.
paul_replies Jul 31, 2009 10:29 PM
i would put in an aftermarket radio...but thats just me. almost all of the aftermarket radios will be better than the stock.
