You could either pry it open and replace the parts that you break or were already broken or you can take the center console panel and the dashboard side panel and you could remove the glove box that way. By the way, this is where you post suggestions for the forum. Post in the Cabrio or general tech forums in the future. You'll have a better chance of your post being seen.
__________________
2000 2.0 Jetta
ECS Underdrive Pulleys
ECS Intake
ECS FPR
ECS Stage 1 Clutch Kit
Autotech Oil Cooler
Brembo Drilled and Slotted Rotors
Borla Cat Back
Magnaflow Cat
