Unsolvable problem?! 2008 Touareg 2
Old 02-02-2016, 01:47 PM
austinlogan's Avatar
Default Unsolvable problem?! 2008 Touareg 2
Hey all-
Brand new to the forum, so apologize if I am posting in the wrong area, or missing relevant information. I am desperately seeking help as I cannot find the issue. Here's the run down.
I have a 2008 Touareg 2, V8, 4.2L.
I bought it used (~95k miles) and almost immediately had an issue. #5 is misfiring. Since then, it has been in the shop 10-12 times with no resolution. Here is what I have done so far:
  • Put in all new plugs/coils
  • sent the ECU to SIA electronics in Chicago for testing - no errors
  • replaced the injector with a new injector on #5
  • swapped #1 for #5 (plugs/coils)
  • checked the harness (dealership said they did this, but not sure if they did or are just tired of me)
Through all this, #5 is still misfiring. The dealership is out of options, suggesting that the ECU is faulty and needs to be replaced ($1600) or they need to swap the #5 injector with #1 to see if that is the issue (~$1000+). Neither of these options sound reasonable because a) the ECU was already tested and b) the injector is brand new, yet the exact problem (#5 misfire) has persisted before and after the injector replacement.
What the hell do I do?!?
Old 02-02-2016, 07:16 PM
You don't say where you live?
10-06-2010 06:25 AM
comeinchina
10-16-2009 03:02 AM
jracknicu
06-04-2008 05:29 PM
torres
10-05-2007 06:10 PM
vw used touareg
09-11-2007 05:32 PM
Quick Reply: Unsolvable problem?! 2008 Touareg 2
