Passat Tdi instrument cluster
Old 01-29-2017, 08:45 PM
Dustin12335's Avatar
Default Passat Tdi instrument cluster
i have a 2014 Passat tdi and the instrument cluster is having issues. Here is the weird thing it works until the car starts. Then everything turns off no spedo fuel rpm nothing anyone ever seen this? I checked fuses but generally if it was blown it would not turn on at all. I'm out of ideas and need help
Old 01-30-2017, 07:12 AM
Old 01-30-2017, 01:24 PM
Tanin Auto's Avatar
Former Sponsor
Hi, Tanin Auto Electronix here. We are vendors on the site that specialize in instrument cluster repairs. Though we can't diagnose without seeing the cluster, here is one thing we would suggest first:
The issue could be a loose connection in the wiring harness. So we would start there if we were you.
The other thing is that it could be in the cluster but we would't know til we had the cluster and ran diagnostics on it.
Diagnosis
If we do run diagnostics and a cluster is not repairable, we locate replacements and program the correct mileage into them for customers.
So, if you exhaust all other issues and need to give us a call, feel free and we would be happy to help out! Good luck!
Old 02-17-2018, 05:15 PM
Lhos's Avatar
Default Immobilizer active
hi i have an immobilizer active issue so i want to do an immo off until i will found a used dash instruments and replace it with my faulty one.
Can i do this with odis VAS6154? (Immo off and reprogramming a used dash instruments)
Last edited by Lhos; 02-17-2018 at 05:20 PM. Reason: Me too i have an immobilizer active issue
dadi83
04-16-2011 10:57 AM
DoloresB
09-19-2008 04:16 PM
adet16v
01-12-2007 11:28 AM
mastershake_phd
09-12-2006 04:22 AM
aquaman
09-07-2006 04:31 PM
Quick Reply: Passat Tdi instrument cluster
