Oil Pressure on 2002 1.8L Turbo - Volkswagen Forum - VW Forums for Volkwagen enthusiasts
Reply
Thread Tools Search this Thread
Old 10-04-2007, 08:43 PM
Default Oil Pressure on 2002 1.8L Turbo
Oil pressure light began going on intermittently immediately after the car was repaired for a new Cam Chain Tightener, water pump, timing belt, and rebuilt Turbo. Fearful the engine might have sludge, I also had the mechanic drop the pan and clean the pick-up screen while he was doing everything else. Mechanic reported slight sludging when he tore into the engine.
Light goes on when under moderate load, and will cycle off if I shift to neutral and coast for a couple seconds.
Any ideas?
[align=left] [/align]
Reply
Thread Thread Starter Forum Replies Last Post
Low Oil Pressure Light-02 Passat-Oil Sludge-Noisy Valves JL Volkswagen Passat 1 03-27-2008 09:57 AM
Install oil pressure sender in oil temp sender location? Boy_Narf Volkswagen Golf 0 03-23-2008 02:48 PM
01 1.8 turbo sucking oil in turbo? swampback Volkswagen Jetta/Bora 0 12-23-2007 06:33 PM
Jetta oil Pressure/Oil Cooler sirhcsenrab Volkswagen Jetta/Bora 3 04-03-2006 02:10 PM
oil pressure sender install shapiror General Tech 0 11-20-2005 01:43 PM
Tags
18, 18l, 2002, chain, clean, jumped, labor, light, liiter, oil, pressure, rebuild, screen, time, turbo, volkswagon, vw
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
